Title: Linear Actuators Post by: redreek(the stig) on Thursday, 28 May, 2009, 11:01:42 AM Hi all.
I thought some of you maybe interested in these,I have seen and installed a set of these in a local eureka (not my eureka)and the kit seems to work well they lift fairly quickly i'm not sure how fast compered to the linak lifters but are quicker and quieter then the ones my eureka.I have checked postage cost and it will be around $85.00 USD so when landed here in NSW they work out $585.00 AUD that is'nt too bad with the remote kit & mounting kit included(you would only use the lower mounting kit). Darren. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&_trkparms=tab%3DWatching&item=200343794041&viewitem= Title: Re: Linear Actuators Post by: redreek(the stig) on Thursday, 28 May, 2009, 11:06:41 AM here's more info on the lifters---LACT8 are the ones we would need.
LACT2, LACT4, LACT6, LACT8, LACT10, LACT12 (4"-10" Models ) Part Number LACT2P LACT4P LACT6P LACT8P LACT10P LACT12P. Input Voltage 12VDC - 4.5 amps draw (Recommend 10 amp fuse) Max Push/Pull 110 lbs Static Load 550 lbs Max Speed 0.59 in/sec (15 mm/sec) Stroke Length 2.0 inches 4.0 inches 6.0 inches 8.0 inches 10.0 inches 12 inches Retracted Length 6.22 inches 8.23 inches 10.24 inches 12.24 inches 14.25 inches 16.26 inches Extended Length 8.22 inches 12.23 inches 16.24 inches 20.24 inches 24.25 inches 28.26 inches Duty Cycle 20% IP Grade IP 63 |
