Sunday, 17 May, 2026, 11:41:44 AM *
Pages: 1 2 3 4 5 [6] 7 8   Go Down
Author Topic: Andrew's Project (Agroeureka)  (Read 290769 times)
0 Members and 17 Guests are viewing this topic.
« Reply #75 on: Monday, 14 June, 2010, 12:29:04 PM »
not bad andrew, you should be quite proud of your achievements so far. its looking good. the t-shirts always aid the calming down Wink
ireek
« Reply #76 on: Tuesday, 15 June, 2010, 08:37:34 AM »
looks good andrew, whats the engineer say about all your modes.
« Reply #77 on: Tuesday, 15 June, 2010, 11:35:46 AM »
The engineer keeps having to look at his text books.
He is ok at present but we will have a big argument when i fit the turbos.
« Reply #78 on: Tuesday, 06 July, 2010, 08:54:27 AM »
wow them wheelis huge great size...
« Reply #79 on: Monday, 13 September, 2010, 10:51:38 AM »
Ok Ok its been a while but we have progress
Picture 005 set up for the steering using two steering boxes
Picture 006 Body fitted for test 200 my daughter is washing the body and would like me to start the painting
Picture 007 Anothere shot of the body on the chassis not the fors stud patten and wheels (also the Bond numbered picture so i had to post it)
Andrew 822
« Reply #80 on: Monday, 13 September, 2010, 10:56:02 AM »
Forgot to say the steering system will have a damper fitted i hadent painted the braket when the picture was taken
« Reply #81 on: Monday, 13 September, 2010, 12:33:41 PM »
Looking good Andrew. About the red dodad on the steering box. I've read a few things over the last few years about how that's the last thing you want there. From what I understand is that the material (Nyroprene?) isn't designed for those sorts of forces seen during steering and it sheers apart. One story the unit was less than 6 months old.
« Reply #82 on: Monday, 13 September, 2010, 10:38:09 PM »
Yes thanks for the heads up
I did some R/D before purchase and found most of the storys come from installations that allow the unit to deflect or move in multiple directions if these loads are removed  and the unit only is transmits steering loads the units last fo a number  of years.(I bought 2 just incase)
« Reply #83 on: Tuesday, 14 September, 2010, 09:27:10 AM »
Fair enough. Might be an idea to keep that spare in the car.  Wink
bushboy
« Reply #84 on: Wednesday, 15 September, 2010, 01:02:35 AM »
Andrew,
I have thought about doing the "twin steering box" trick on my reek here in the UK.  Did you use a LHD steering box? Will the damper fit in the same position?  Are you using a std damper?
Bushboy
« Reply #85 on: Wednesday, 15 September, 2010, 01:42:03 AM »
Steering box was my orignal with a left hand arm fitted.
Damper will not fit in same position is now to be mounted on the other side of the center arm.
Yes standed damper custon mount off the chassis not the beam.
I will look through my pictures on the week end and post one showing the completed setup.
bushboy
« Reply #86 on: Wednesday, 15 September, 2010, 08:58:12 PM »
Andrew,
Pics of the completed set up would be appreciated.
Thanks
Bushboy
ireek
« Reply #87 on: Thursday, 16 September, 2010, 05:16:12 AM »
Dont use that red thing on your steering. That will break without notice in about 3 weeks. The vw forum also say they are bad. You are best to use original rubber type. just a heads up, looks great.
Anthony
« Reply #88 on: Wednesday, 10 November, 2010, 04:21:20 AM »
wow man that's come leaps an bounds since i seen it last  did it make it too coffs...
jateureka
« Reply #89 on: Sunday, 06 February, 2011, 01:42:52 PM »
Hi,
can you give some more details about the twin steering box set up and it's benefits please.
Pages: 1 2 3 4 5 [6] 7 8   Go Up
