Thursday, 16 July, 2026, 04:25:04 PM *
Pages: [1] 2 3 4 5 ... 8   Go Down
Author Topic: Andrew's Project (Agroeureka)  (Read 295160 times)
0 Members and 3 Guests are viewing this topic.
« on: Sunday, 20 September, 2009, 07:14:53 AM »
Will post my project updates from now on in this thread as it is all coming together now slowly.
See attached pictures of my car out in the sun for the first time in 3 years with roof attached (thanks Simon AKA Metalsmith)
And yes if you wont to live in Stanhope Gardens two homes are for rent in back ground of both pics.
« Reply #1 on: Monday, 09 November, 2009, 08:27:45 AM »
It’s been a while but the attached picture is of brake and clutch master cylinders being mounted.
New high speed shopping centre front end fitted (kidding) :Smiley
I have now taken the body back off to allow access to  front end for fitment of front end ,braces, master cylinders  and wielding of frame as it is only tacked at present.
The steering rack /box has become more involved than I had hoped at present I have an EMPI rack , a Vw box and a Hyundai excel rack on the way. I have found space to be a problem needing to have wiring, air ducts, steering components, and master cylinders and throttle linkages all in one spot has confined space. I have decided to look at all three set ups and use the best compromise.
« Reply #2 on: Monday, 09 November, 2009, 09:41:45 AM »
Attached picture of rear bar work ready for final welding and end capping.
Also showing lawnmower with over sized carburettor. Shocked
« Reply #3 on: Monday, 09 November, 2009, 09:44:30 AM »
Another picture of the pedals and template for accelerator pedal mount .
« Reply #4 on: Monday, 09 November, 2009, 09:56:49 AM »
looking good.can't wait to see it done and on the road
..Darren
« Reply #5 on: Thursday, 19 November, 2009, 12:53:12 PM »
agroeureka ...
as they say slow an steady wins the race ..will look a treat when it's complete ..
get it done quick an you'll make yourself sick..
« Reply #6 on: Thursday, 19 November, 2009, 01:16:13 PM »
If its not to hot this week end should have a big update.That is some hours >30 degrees
Also full time employment would help my speed of my project.
Have found my front beam was bent will be getting a replacment on saturday. This will allow me to fit the beam and fabricate my beam braces and finalise the location of my master cylinders.
My fuel tank is reinstalled to check pipe runs. The clutch slave cylinder location and operation , final welding , a number of holes for services (power,brake lines, fuel lines,air ducts ect ) and seat belt mounts the chassis can go to powder coating.
Then i can start body work?Huh?Huh?Huh?Huh?? 2-3 months.
Paint 1 month
Fit out 1 month
Rego 1 month
Contingency 5 months
So may be ready for next years meet.
« Reply #7 on: Wednesday, 25 November, 2009, 12:11:45 PM »
money can do that to all dreams too... Huh?
« Reply #8 on: Wednesday, 25 November, 2009, 12:46:26 PM »
Just a small up date i was unable to pick up my new front beam on the weekend (Wife said i must fix the ducted ac)
The attached picture is of the test assembley of the front end to check wheel clearances to the master cylinders.
I have also test fitted the beam braces to and will have to remake to fit the lowered pan.The mountung points at the pan end will not clear the pan lowering braces.
If anyone is thinking of fitting beam braces thay will interfere with the front under sill.
PS Sorry about the picture quality my phone has been found not to like dust and water (work) and i have to use an old one.And i can not up load it.27/11/2009 it worked
« Reply #9 on: Wednesday, 25 November, 2009, 01:13:08 PM »
im experiencing that too trying to upload one here to... Embarrassed
« Reply #10 on: Wednesday, 06 January, 2010, 02:37:46 AM »
Picture 1 seat area boxed out double skined with flat bottom
Picture 2 Rear bar work being final welded horn braces being added to fit 930 porsche cv,s
Picture 3 Front under sill mount being cut
Not far to go now has to be at powder coaters 27/1/2010
« Reply #11 on: Wednesday, 06 January, 2010, 11:00:35 AM »
your doing some great work on it ... a priceless reek come's to mind... Cool Cool Cool Cool Cool
« Reply #12 on: Monday, 25 January, 2010, 01:28:46 PM »
Did some more work today not a big step but getting there
Picture one pan half finished
Picture two new front under sill mount/front end brace
« Reply #13 on: Monday, 01 February, 2010, 09:46:43 AM »
as always very cool the work you are doing to it.. Cool Cool Cool Cool Cool
« Reply #14 on: Monday, 01 February, 2010, 12:08:15 PM »
Picture one Bar work for gearbox also showing mounts for fuel pumps and filters
Picture two Sealt belt mount ready for welding one tacked in background
Pages: [1] 2 3 4 5 ... 8   Go Up
