Tuesday, 16 June, 2026, 02:42:15 PM *
Author Topic: Linear Actuators  (Read 17374 times)
« on: Thursday, 28 May, 2009, 11:01:42 AM »
Hi all.
I thought some of you maybe interested in these,I have seen and installed a set of these in a local eureka (not my eureka)and the kit seems to work well they lift fairly quickly i'm not sure how fast compered to the linak lifters but are quicker and quieter then the ones my eureka.I have checked postage cost and it will be around $85.00 USD so when landed here in NSW they work out $585.00 AUD  that is'nt too bad with the remote kit & mounting kit  included(you would only use the lower mounting kit).
Darren.
 http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&_trkparms=tab%3DWatching&item=200343794041&viewitem=
« Reply #1 on: Thursday, 28 May, 2009, 11:06:41 AM »
here's more info on the lifters---LACT8 are the ones we would need.
LACT2, LACT4, LACT6, LACT8, LACT10, LACT12
(4"-10" Models )
Part Number
 LACT2P
 LACT4P
 LACT6P
 LACT8P
 LACT10P
 LACT12P.
Input Voltage
 12VDC - 4.5 amps draw (Recommend 10 amp fuse)
Max Push/Pull
 110 lbs
Static Load
 550 lbs
Max Speed
 0.59 in/sec (15 mm/sec)
Stroke Length
 2.0 inches
 4.0 inches
 6.0 inches
 8.0 inches
 10.0 inches
 12 inches
Retracted Length
 6.22 inches
 8.23 inches
 10.24 inches
 12.24 inches
 14.25 inches
 16.26 inches
Extended Length
 8.22 inches
 12.23 inches
 16.24 inches
 20.24 inches
 24.25 inches
 28.26 inches
Duty Cycle
 20%
IP Grade
 IP 63
