Tuesday, 22 September, 2026, 11:10:40 PM *
Author Topic: WA reek back on the road  (Read 24853 times)
I reek
« on: Wednesday, 10 July, 2013, 03:35:20 AM »
Posted some photos of my restored reek back on WA roads in a new incarnation
http://s480.photobucket.com/user/eurekacarclub/library/Member%20Rides/Leifs%20rebuild?sort=3&page=1
She uses a remote control circuit modified to include remote immobiliser, canopy lift control, limit switches, and will auto immobilise after a couple of minutes when the key is removed from the ignition.
I've kept the 2L dual carb type 1 engine but with new electronic points and she runs great and will get up and go when I want. The 4 into 2 exhaust is very loud  Evil so I'm thinking of changing the system a little to quieten it down.
Things to finish - the interior upholstery, side windows (including seals & pop-out mechanism for airflow), mounting heating and cooling fans with climate control electronics.
Speaking of side windows, I have some 3mm polycarb ready to go but is there a one piece seal rubber people use? I was going to go with a slotted channel along the top edge as you can see in the photo with a rubber seal attached to the bottom of the polycarb but this creates a problem at the two mounting points where the two separate seals meet. It doesnt look smooth and small gaps are left between seals.
Leif
« Reply #1 on: Wednesday, 10 July, 2013, 11:57:51 AM »
Certainly looking smart!! I especially like the aerocatches on the bonnet. I was thinking of doing the exact same thing! So any close up photos of the instal would be great.   Wink Grin
« Reply #2 on: Saturday, 13 July, 2013, 02:51:48 PM »
My reek has electronic points, but began fouling plugs and misfiring above 2500rpm.
Tomorrow will do some fiddling and hit it with the timing light. I think I've figured it out, but damn it was a tricky one to solve.
